RCU Forums - View Single Post - ESC on Parkzone Typhoon 2
Old 04-10-2008 | 11:49 AM
Leo L
Default RE: ESC on Parkzone Typhoon 2
Stick40,
See if this happens when the antenna of your transmitter is pointing directly at the plane. I've been told that the radio signal is weakest along the axis of the antenna. My Typhoon, and all of the other planes that I equiped with "replacement" Typhoon Rxs so that I can use the Typhoon transmitter, have this problem. As long as I make sure to keep the plane from crossing the line of the antenna, I get no glitches. But if I allow the plane to fly across the antenna's projeection, sometimes it glitches and sometimes it does not.
