ORIGINAL: klhoard
ORIGINAL: martenson
. . .<snip>. .
P.S is it dangerous to fly a plane where the wing sheeting is getting unglued(it is not much but you can see the area), I really want to fly his old Crusader.
Get a syringe, fill it with polyurethane glue, and inject it into the voids. The glue will foam up and fill the voids. . . You can warm up the glue when its in the syringe to make it more liquidy. . .
YES, fix the sheeting issue! Often sheeting coming off in one little spot is simply a symptom of a more systemic and widespread problem. I would carefully go over the entire wing to make sure this isn't happening anywhere else.
