RCU Forums - View Single Post - Stearman Problem
Old 05-16-2003 | 10:50 AM
Metal bender
Default Incidence
When I setup wings (and it looks like you have a wing warp problem) I use 2 Robart Wing Incidence meters. I put one at the root and adjust incidence there as necessary. The other goes at or near the tip. I adjust the tip to match the root. I will move the tip mter from tip to tip but leave the root meter on so I get accurate relative readings al the way down.
I had a biplane that seemed to change flight characteristics from flight to flight. This method fixed it.
