RCU Forums - View Single Post - CP PRO Head speed
Old 04-10-2008 | 11:22 PM
Carljw
Default RE: CP PRO Head speed
Glenn
The expo setting is that + or - 25% and the numbers on the left should I just leave them at 100%. And the rudder expo did you change that also. I have a G90 and it worked good with the stock TX but I am haveing a hard time finding the right setting.
I was haveing a hard time with my pitch it was like 15 deg with the stick up in norm flight mode. I tried lowering the throtle high end down but i had it down to like 50 and I figured that was no good so I went into the swash mix and lowered the pitch to +33 to get it to 12 deg at high stick. Not sure if that was a good move or not. Mabey the travel Adj would do it ,I have the throtle adjust at +100%. That is what teck support gave me for my travel adj.
Thro +100
Elev +80
Gyro + 100
Aile +80
Rudd +80
Pitch +100
Not sure if thats correct or not.
The thing is driving me baty but I guess once i get the settings correct it will be worth it.
Carl
