RCU Forums - View Single Post - SuperTigre 90 on Gasoline
Old 04-11-2008 | 08:58 AM
JIMARRINGTON
Default RE: SuperTigre 90 on Gasoline
That is great news Jezmo. Looking forward to more reports on how it holds up and how it flies. I have one that I would like to put in a TF FW190 kit and run it on gas. When and if I get the XYZ replacement ignition I ordered from Hobby City and it turns out to be a reliable ignition, converting to gas on glow might turn into a very econimical alternative. I have since found out the XYZ has a US dealer where the ignition can be ordered for $55.00 including the hall sensor. Like I said, if it works it will be a good deal.
I would also like to see some pictures of your set up if you can get them.
Jim
