RCU Forums - View Single Post - First Post - Seeking Trainier Advice
Old 04-11-2008 | 12:32 PM
Missileman's Avatar
Missileman
Default RE: First Post - Seeking Trainier Advice
ORIGINAL: PipeMajor
I just sold a NIB OS .46 FX but kept my Thunder Tiger .46 Pro - mainly because of the needle valve. The OS has a remote NV which you can't rotate the orientation other than horizontal. I'd have to cut into the cowl of my trainer to accomodate the OS. The Thunder Tiger has a conventional carb mounted NV which is angled back and plenty far enough from the prop for safe operation - and NONE of us EVER reaches OVER the prop to make adjustments, do we?
The OS 46 AX can rotate the Remote Valve to 2 positions. horizontal or vertical. I have the one in my Kadet Senior vertical just to avoid making another hole in the cowl.
