RE: scratch built c130
the carbon fiber spars are 1/2 inch by 1/4 inch tapering to the tip.. the wings will be st8 on top side ... only had one bolt in the spars to take pics. the body is stringers and foam.. i now have everything glassed.. doing the the tail in 1.7oz dacron... one primer coat on and started sanding... i'm planning two coats of primer.. most of it will be sanded off.. maybe auto lacquer for finnish,, not decided yet.... working engine mounts at present.
