RCU Forums - View Single Post - Futaba FASST feedback and TESTING
Old 04-11-2008 | 02:34 PM
  #728
GrayUK's Avatar
GrayUK
Default RE: Futaba FASST 6
Take great care to ensure the path is correct (pic 9/10) and the grommets sit in to the correct locations (pic 11)
Pic 11: Grommets in position, ensure no strain on the aerials inside the rx.
Pic 12: Clip case back in to position, ensuring that the grommets are correctly located as you do so. (Orange arrows)
Well, that is it, job done, now test the rx and ensure you do a full range check before use.
Hope this is of use to you all.
Paul
ID:	927574   Click image for larger version
