RCU Forums - View Single Post - Diesels are dead - apparently!
Old 04-11-2008 | 03:39 PM
pe reivers
Default RE: Diesels are dead - apparently!
The can is gas pressurized. Hold upside down to get the gas pressure off. Then drill holes in the can to drain the contents. Do it outside. Driilng may cause sparks that can ignite the ether. I rather buy the ether in hospital supply stores. They may supply to you if you can convince them of your peaceful intentions, or supply them with a police statement (convince the police first )
