RCU Forums - View Single Post - Diesels are dead - apparently!
Old 04-11-2008 | 08:38 PM
AMB
Default RE: Diesels are dead - apparently!
Heres the drill again for anyone who missed the "ether" in a spray can
First try and get John Deere starting fluid 80% ether
OUTSIDE hold the can upside down and depress the sprayer most of the pressure will be bled off , it will just stop spraying when this happens
Still securing the can inverted punch a hole in the bottom near the edge with a nail,
use a jar like a one qt mason jar to collect the ether ( turn the can upright of course)
then pour it at once into a metal can I use an empty 1 qt one that alcohol, acetone etc comes in
Make sure cap is tight and store in the refrigerator till ready to make the brew of your choice
with the cap on tight you do not have the refer smelling of ether martin
Even if you buy ready made model tecnique fuel in the UK remember the engine will only use about half as much as running on glow so your cost per hr of fuel is about the same
