RCU Forums - View Single Post - Bore x stroke = displacement ???
Old 05-01-2003 | 03:48 PM
Scar's Avatar
Scar
Default Formula for displacement
Find Pi on your calculator, or just use 3.14159
Take half the bore, that's r (the radius)
Then the displacement is Pi times r times r times the stroke
Displacement = pi x r x r x stroke
If you use mm, the answer will be in cubic mm, divide by 1000 to get cc (cubic centimeters)
If you use inch, the answer will be in cubic inches
Good luck!
Dave Olson
