RE: Running hot.
Richen the HSN a little 1/4 turn, thats should fix the problem. But as soon as the weather gets warmer you will need to lean it out again. But dont wait for the warmer weather to come to you if your still going to run it. Cause you will do a lot of damage to the engine....
