Yes. Yes I do.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCJD6&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXBJD7&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDZ89&P=7
But if I understand your post, you will drop bombs, turn on the lights and set the brakes all at the same time. If you only have one receiver channel available you have to limit it to one choice. Unless you get really clever and set up a sequential step processor (mechanical or electronic) to do them in sequence for each energization of the switch. Lights, then bomb, then brakes. Or: brake if flaps activated, bomb if throttle over 1/2, lights if wheels retracted?????
