RCU Forums - View Single Post - accessory module
Old 05-02-2003 | 10:33 AM
roadtrip's Avatar
roadtrip
Default accessory module
Heavy Date, you said that nav. lights can be turned on from the ground. How do I set that up? Does a switch on the transmitter activate something in the plane, other than a servo, such as the landing lights with the retracts? Is there a way to set up bomb drops the same way? Also, if I couple up elevator in with the brakes, I won't be able to taxi and take off.
