My own experiences indicate that lowering the oil ratio from 18% to 12% has actually resulted in cooler-running engines here. Perhaps that''s because we''ve also changed rom PAG-based synth/castor blend to an ester-based synth/castor blend I don''t know.
Hey Xjet.
Have you tried lowering the oil % in an engine to 12 %, which already have been broken in with 18% oil? Will the engine loose its compression?
I have a TT pro 46 that is broken in, and a Super Tigre GS45 that even after 1,5 liter fuel (5 % nitro, 3 % M and 12 % ML70) is not broken in. For the Super Tigre I have thought of mixing 0 nitro, 3 % M and 9 % Fuchs AeroSynth 2, but I am not sure what to mix for the TT.
