RCU Forums - View Single Post - Homelite Flywheel Gap
Old 04-14-2008 | 07:15 AM
pe reivers
Default RE: Homelite Flywheel Gap
I posted an answer that got lost also.
The gap matters, and should be as small as possible without the parts touching the flywheel.
I use a postcard inserted between coil and flywheel before I tighten the coil to the engine. After tightening the coil fasteners, often the gap has become smaller than the postcard thickness, and is just right.
