G''day Mate,
Turn the carby around, so the needle valve is on top, then the throttle will be lower, & easier to hook up.
You could use a steel push rod, bent in a "U" shape with a ball link on the end of it, to hook up your throttle.
Have a look here, lots of info,
http://saito-engines.info/index.html
