RCU Forums - View Single Post - Official HPI Hellfire Thread
Old 04-14-2008 | 09:11 AM
  #1196
hellfire07
Default RE: Official HPI Hellfire Thread
Hey Guys,
Can anyone help with a race setup for a HF RTR on clay track. (e.g. diff/shock oils, springs, tiers, and any other settings I should look at )
This is the track[image]http://www.rctech.net/forum/attachment.php?attachmentid=322692&d=1206251774[/img]
I''m new to RC and need some help. When I have had practice it under steers into and around corners then oversteers out fishtailing when accelerating. I have upgraded the the radio to an Airtronics MX-3 FHSS, fitted a HF rear wing, changed the shock oil to 50wt front and rear with the 1.6mm tappered piston holes, and have on order 2 Hitec seros (HS-5955TG steering, HSC-5998TG throttle/brake) everything else is stock and in the stock positions. I have been told to try 15000wt front, 20000wt centre, and 10000wt rear diff oils and Proline Crime Fighter tiers. Is this heading in the right direction?
Thanks for your help.
Mark.
