RCU Forums - View Single Post - Nitroplanes Tucano
Old 04-14-2008 | 12:55 PM
jmohn
Default RE: Nitroplanes Tucano
I installed Spring Air retracts for the mains and nose gear. You could also use mechanicals, but it would be more work on the nose gear. The wing install is easy just install the blocks and some light ply. The nose gear took some creativeness to get them installed. I used an old set of gas engine mounts to install the nose gear on. Went fine after that.
Jeff
