Im not new to the sport, ive been flying for about a year and a half on my falcon 56, I was looking for a reliable and easy to fly airplane, which is definatley what i have now, to tame for for desires. I would call it a sunday cruiser, but it is fun to fly after a long break over the winter. I may try putting two servos in the wing, that is a good idea. First i guess i will completely max out the servo arms and see what happens. I thought the sport wing design would be a bit more "able" upside down and with rolls but you get what you get, being a flatbottom wing i should have seen it coming. I have a wing to a bridi krafty 60 which i may buy next, it has a semi-symetrical wing, or i may just go for a kaos. Also the plane will roll pretty quickly with ruddder kicked in so I could just learn to use the rudder more often
. It is not the best at self righting itself. It seems like it would be bad to get disoriented end up upside down and not have enough aileron authority to roll back over quickly. But like i said it flys great just cuising around at full throttle.
