RCU Forums - View Single Post - CA Hinge failures
Old 04-14-2008 | 07:52 PM
jrf
My Feedback: (551)
Default RE: CA Hinge failures
Sounds like you are installing them right. The hacksaw blade may be making the slots a little bigger than ideal, but I don''t think that would cause them to fail at the hinge line.
It is pretty well accepted these days that a CA hinge will fail at the hinge line from overstressing caused by the very high deflections and constant surface movement of 3D flight, OR from high vibration levels, such as in a twin or when using a gas engine.
Could one of those be your problem?
Jim
