Airtronics RD 6000 ......help!
Both swtichs on the outside top need to be towards you. Not the ones on the front but the toggle switches that stick straight up. The throttle stick needs to be all the way down. If the throttle stick is 1 notch up the radio will beep like crazy.
There was a thread awhile ago about a guy having his RD not coming out of throttle high mode. He ended up sending it back to Airtronics to get it fixed. It was something about the gimble not setting right and causing the switch to not open.
Dru.
