RCU Forums - View Single Post - Prop Sizes?
Thread: Prop Sizes?
Old 04-15-2008 | 12:00 PM
asmund
Default RE: Prop Sizes?
Lower pitch and bigger diameter, it evens out you know. A 17-4 APC is marked "w" meaning wide and gives about the same load as a normal 17-6 so the engine will not tell the difference.
A bigger diameter prop with smaller pitch will pull better than a smaller diameter prop with more pitch, that`s exactly what is needed for 3-D. The rpm on the engine itself will stay about the same
