RCU Forums - View Single Post - CA Hinge failures
Old 04-15-2008 | 07:04 PM
rideon67
Default RE: CA Hinge failures
Hinge does NOT pull out. It always breaks in half at the hinge line. If you miss the first one (which is easy to do cause the failure is not obvious) a couple of more flights will result in the entire surface coming off. In any case, I''m done with CA hinges. Just add $10 to every plane I build for Robarts.
