RCU Forums - View Single Post - 31cc gas airboat
Old 04-15-2008 | 11:20 PM
DONS BOAT WORKS's Avatar
DONS BOAT WORKS
Default RE: 31cc gas airboat
ORIGINAL: luckytempo93
DONS BOAT WORKS... thats a really nice cage you have there. what size prop were you using and did you follow the advice from above on what size to make the rudders? i have a 16X10 3blade and its 1.5" off the bottom of the boat. so the tip of the prop is 17.5" tall. i was thinking that i would make mm rudders 14" tall and 6" wide. what do you all think.or will that be too big and would not handle propertly
The cage was built for a 10" prop, but I could only find a 3 blade 9X7" prop so the spacing is 4" apart.
Thank You
Don M.
PS
Just call me Don.
