RCU Forums - View Single Post - Excessive down trim in 8' Beaver
Old 05-02-2003 | 01:05 PM
BillHarris's Avatar
BillHarris
Default Excessive down trim in 8' Beaver
You might also check the wing incidence. Relative to the stab, it shouldn't be more than a "couple of degrees" positive.
I assume that you have to use the excessive down-trim for a cruising throttle.
A couple of degrees of engine down-thrust would be adequate for this plane.
And check the balance. Tail-heavy may require down-trim to lift the tail, in addition to making the flight a tad squirrely.
