RCU Forums - View Single Post - Excessive down trim in 8' Beaver
Old 05-02-2003 | 03:05 PM
Mike Noin
Default Excessive down trim in 8' Beaver
Thanks for the replies guys.
The balance is bang on where the plan calls for it to be and the incidence looks about right, although I do not have an incidence meter to measure exact degrees. The excessive down trim is at half throttle and the plane does not require more down trim as I increase throttle. It seems that once I get it trimmed out for straight and level flight it does not need to be changed for different throttle positions. Once the trim is in the plane flies like a dream, I just don't like the look of the elevator. What about a trim tab? To change the incidence now would require major rework of the wing mounts or the tail feathers.
