RCU Forums - View Single Post - Bragging about the .55 AX
Old 04-17-2008 | 12:17 PM
yetti831
Default RE: Bragging about the .55 AX
The TH website says the engine is set at 1.5 turns out of the box. I'm not sure what to do at this point, because this engine will not run consistently.
Also, someone mentioned the pinch test for low speed at idle. I'm pinching at idle, but nothing is happening. I've pinched and held for ten seconds or more, which doens't suprise me, since the fuel consumption is low. What am I doing wrong?
P.S. Just wondering. Will the engine run with the tubes from the tanks hooked up incorrectly? Fuel to exhaust , exhaust to fuel. If I thought about this, I could probably answer the question myself. [:@]
