RCU Forums - View Single Post - Servos Question (Is it worth it)
Old 04-17-2008 | 12:36 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Servos Question (Is it worth it)
Futaba S3004 has the same torque and ball bearings, but is slightly slower. Also someone pointed out that Hitec is the only one to use the Karbonite, and there's probably a reason that the 'name brands' don't use it.
SPECS: Speed: .23 sec/60° @ 4.8V .19 sec/60° @ 6.0V Torque: 44 oz-in (3.2 kg-cm) at 4.8V 57 oz-in (4.1 kg-cm) at 6.0V Length: 1.6" (41mm) Width: .8" (20mm) Height: 1.4" (36mm) Weight: 1.3 ounce (37.2 grams) Connector: "J" type with approx. 5" wire
