Mike, here is a picture of my project, hopefully it will look like a Duelist when done...
Question for you Mike, did you get any written building docmentation with your plans?
I'm working strictly off the plans, some of the detail isn't clear especially the front half of fuselage, but thanks to your pictures it has helped me quite a bit, Thanks....
I'm dreading when the time comes to prep the fuselage for the side sheeting, there is some sanding shaping of the top and bottom 1/4" sheeting that runs from the canopy and back and from the trailing edge of wing to the back.
Did you cut out the wing saddle and cokpit area out of the sheeting before you glued it to the fuselage?
I'm open for any sugestion that you might have, by the way this is my first build working strictly off the plans...
Ulf
