RCU Forums - View Single Post - Stuka in the Bones
Old 05-08-2003 | 10:42 PM
SNAKE STUKA
Default Stuka Light
Looks like you are doing a great job on the stuka.I used a flashlight assembly on mine.You need to fit the light in between
the leading edge of the ribs.then make the lens from clear thin plastic.If you attach a micro switch to the flap servo it will turn on when you land. GOOD LUCK -SNAKE STUKA
