RE: first rc build
ok heres all the hard ware that i intend to use for the boat. let me know if im missing any thing. i already have 2-6 cell bateries, a remote, and servo for the rudder.
hardware list: (all from offshoreelectrics.com)
Prop part ID: grp-2317.42…………………………………… …………………...$5.50
Strut part ID: ros-stinger-str............................................... .........................................$39.95
Rudder part Id: ros-mini-rud (note: must chose mono rudder style with 2” setback)……………………….$39.99
Flex shaft part ID: oct-oc130L-24c…(assembled)…………………………… ………………………………………….. $19.99
Motor coupler part ID: oct-ocfhe5mm13S(5mm to .130 cable)…………………………………… …………..$9.95
Motor Mount part ID: ose-drmount (standard mount style)…………………………………… …………………$7.49
Turn fins part ID: ose-monofins…………………………………… ………………………………………… ……….…….$29.95
Trim tab part ID: ros-spdt-150……………………………………… ………………………………………… ……………$17.95
Speed control part ID: hl-je600n…………………………………… ………………………………………… ………..$74.99
Motor cooling coil part ID: cen-bjs02……………………………………… ………………………………………….. …$7.99
Water outlet part ID: aero-2010……………………………………… ………………………………………… …………$2.49
Speed 700 8.4volt motor part ID: grp-6316……………………………………… ………………………..…$49.99
Total:…………………………………… ……………………………………….$30 6.23
