RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max
Hi riverrrun, my answers are in brackets below:
1. BUT what about the HOPPING when the sim starts? Can this be corrected by an option setting?
[This can't be corrected and will be addressed in the next version. It is not an issue in most cases]
2. Global scaling is needed. If I change wingspan and LOA, will engine size be changed? I would like to scale down
come of the full size models to match the Aztec.
[There is no automatic scaling. You may change the engine power in the model edit menu]
3. What about minimum (idle) engine speed?
[You can set the idle speed in the model edit menu]
4. On the side of the Antonov AN-2 there is a girl with no knickers and "Ahacmacust" painted on the side.
What is the translation? This is from Addon3.
[Sorry, I have no idea. Perhaps some one can chip in]
