ORIGINAL: ErikElvis
So if Im looking for a multi battery ger which you could ge multiple batteries at once and the option to ge from a outlet from home or at the field what would I choose? It seems with the tritons you would have to buy the appropriate battery connectors seperate. Is this right? And are JR/spectrum and Futaba connections teh same as far as battery ging?
Take a look at the Hobico Accu-Cycle Elite, it does everything you are looking for.
The **ge leads are separate, but easily made if you are inclined.
The Rx ge plugs are universal (except for older Airtronics), but the polarity of the Tx ger plugs
is different between JR/Spektrum and Futaba. Check the pin polarity on the **ger that comes with the radio.
Edit: ** For some reason, the string c-h-a-r will not display in this post...
