RE: Building a DUELIST MK 2 From Plans!
Thanks for the reply.
I'm going to use 1/8" balsa skins for my fuselage. I plan on using Ultracote so I think that I need the extra strength, I don't want to get into fiberglassing...
When you skinned the fuselage did you do it while the fuselage was still attached to the building board?
You don't need to Fax me the information (I don't have a Fax machine), I was hoping for some detailed building information, but like I said before your pictures helped me a lot.
My other plan is to use spruce spars when I get ready to build the wing for a little extra strength, do you think it is an overkill?
