Elevator
I just purchased and put together a Hobbico Superstar 40. Everything seems to be in good shape, I balanced it, etc. but I have one nagging problem. The instructions recommend 1 inch of elevator movement from dead center. I have moved the connector to the bottom of the horn, but am only gett ing about 1/2 inch of movement. Everything else has the recommended movement length. Is the 1/2 inch enough to start with, or do I need the full 1 inch? Any advice on fixing this problem, if it is a problem.
