RE: VQMDL TomHawk 46 ARF Sport "Jet
I'm confused. You said you had an OS 46. Then you said you had an OS fs. The fs engines are 4-strokes, and I don't remember OS making a 46 4-stroke. Or did you mean FSR. More confusion. You said your engine runs lower rpm on an 11x5 than it does on a 10x8? That would not normally be the case, since the 10x8 should load the engine a lot more than the 11x5 does.
Can you straighten me out?
Jim
