RCU Forums - View Single Post - OK newbs, Learn a quick stupid bit of advice from me.
Old 04-19-2008 | 10:25 PM
2slow2matter
Default RE: OK newbs, Learn a quick stupid bit of advice from me.
Yes, it is a good idea to paint the tips of your props to define the outer edge of the disc. Some of the larger MAS are already painted white. Balance shouldn't be an issue if you do it equally on both ends. You can always re-check the balance (as well you should).
