RCU Forums - View Single Post - BVM T-33 Removeable tail kit question
Old 05-02-2003 | 06:52 PM
slushyF16
Default BVM T-33 Removeable tail kit question
I have been trying to sort through this and a call or two to BVM haven't helped as much as I would have hoped, so hopefully you guys will know the answer: As I sit here and read the tail kit manual it mentions three different bulkheads (F-5, F-5A, and F-5B). BVM has assured me there are actually only two, (F-5=F-5A). Now, as I read the directions, they say glue F5 into the forward fuse, and F5B into the aft fuse. That makes sense, except on page 39 of the kit assembly manual, it has a picture of the removeable tail kit with F5 glued into the aft fuse supporting the outer wall of the tailpipe. If this is the case, what supports the aft end of the bypass? Are there truly three bulkheads in there (which I doubt)? If no, which end (STS) does this blasted F5 get glued into? And finally, if it is the forward fuse that F5 gets glued to, why does the manual show it glued into the aft fuse? Help please!
Dave
