RE: BVM Agressor II Build Thread
It has been a litte while, been flying and doing those outside projects.
I did get the wings about 90% done. All the controll surfaces have been cut out and hinged.
The landing gear bays have been cut out and the door assembly's made. Landing gear is installed also. The main retracts are from Sierra Precision. The nose retract will be a BVM.
Just have to cut ouut the bays for the servos.
There will be a servo on eafh flap and each aileron. I didn't trust the bell crank set up. my experiance with them is too much slop at the control surface.
Once all the bays are cut out and built I will get the wing joined. After this is done I will be able to mount the rear wing mount former and start to get the mounts made for the turbine.
