EQ10 issue?
I’m having an issue with the throttle setup in my Yellow P-38 Lightning. I believe I have pinpointed the problem to the EQ10. This is my second EQ10 so I am familiar with its operation. I have the right engine on channel 1-a and the left engine on channel 1-b. During my initial setup the b-servo was acting funny, it would have trouble finding the center of the movement, IE it would hunt a little after stopping. I assumed it was a bad servo and replaced it. Today I was readjusting the low-end endpoint to synchronize the engines idle. I did the a-servos checking the engine RPM then switched the function dial to the b-servo doing the same. When I switched the function dial back to the a-servo the b-servo quite working completely. I manually rotated the servo arm and it was as if the servo was unplugged. I turned the channel and function dials to 0 and recycled the power switch and all was well again. Now I am worried! Do you think I have a problem with the new EQ10?
My other EQ10 is in a Composite ARF 2.6 Yak and worked great for two years. The EQ10 in my P-38 I won at the pilots raffle at the Speedworld Jet Meet this last winter. I’m leaving for the Joe Nall meet in 9 days. I could pull the EQ10 from my Yak but that would require setting up both all over. HELP!!
Danny
