RCU Forums - View Single Post - EQ10 issue?
Thread: EQ10 issue?
Old 04-20-2008 | 04:08 PM
rrritchey
Default RE: EQ10 issue?
Hi Danny,
I think you are seeing a small bug that occurred in the second batch of Eq10s where the servo priority mode is always on. With it on, when you are adjusting the A servo, B will be turned off. If you go to B then A will be on. This has bothered very few people. If you like I can send you a revision where the servo priority can be set as per the manual.
