RCU Forums - View Single Post - Engine idle problem
Old 04-20-2008 | 04:16 PM
Rockman's Avatar
Rockman
Default RE: Engine idle problem
It also could be the angle of your carb in relation to the linkage. Maybe it moved a little and now it is causing the carb to stick. Also are you running a spring or rubber bands to close the throttle. This is good to help stop a runaway vehicle and helps close the carb.
