RE: Another Blue Angel build
generating shapes for the formers not available on the plans has proven to be a challenge. a width and or height can be found but the top or bottom shape of the formers has to learned. by using formers in front or behind the missing formers and by referring to other similar builds i hope i have cut formers close enough to tack to the fuse sides. i then hope to lay planks over a span of formers and check as to whether i have the correct shape. what fun!
david
