RCU Forums - View Single Post - Tetranitromethane and hydrazine
Old 05-02-2003 | 09:09 PM
impulse
Default Tetranitromethane and hydrazine
Not sure if someone has said this but if your wondering what that stuff is i found some info.
Tetranitromethane, also called TeNMe, is a colorless to pale yellow liquid that was first prepared by the action of nitric acid on trinitromethane back in 1861. The Germans used it back in WWII for an intermediate in making other explosives and as a substitute for nitric acid in the V-2 rocket. A pilot plant in New Jersey used to make tetranitromethane blew up in 1953. This compound is rather toxic, irritating the skin, mucous membranes and the respiratory tract. Prolonged exposure to vapors causes damage to the liver, kidneys, and other organs. A concentration of 0.1 ppm in the air is fatal. Mixtures of tetranitromethane with organic liquids tend to form more powerful explosives , but the sensitivity is worse. A list of mixtures has been provided. Tetranitromethane has been proposed as a chemical warfare agent.
Hydrazine is a colorless, mobile liquid which is used as missile fuel. It is also used to remove oxygen from boiler water to prevent corrosion and as a building block for agricultural chemicals.
