Cox reed valve performance
Thanks Dereck. Hope yours turns out good!
Instead of cutting the threads in the lathe, if you want to fool with cox cylinders a lot, make yoursefl a tap (just plain steel and case harden the cutting edges with casenit)
I have used this one LOTS on aluminum and it cuts a perfect thread for the cox 049, have one for the 020's also. Takes about 1/2 hour to make. Timesaver!
Andrew
