RCU Forums - View Single Post - 50cc Sukhette Build Thread, now in progress!!
Old 04-21-2008 | 11:06 AM
  #968
aaxiss's Avatar
aaxiss
Default RE: 50cc Sukhette Build Thread, now in progress!!
Oh one other quick question, almost a poll if you will, so say..you built you plane and lay out the electronics and fuel system as close to center line as possible ad off set the throttle servo install by putting your switch on other side of fuse . pretending the fuse is laterally balanced perfect without wings on . I know it's not bt with wings on are you noticing a severely out of balance plane or just having to add a tiny amount of weight to wing tip or even better move a battery slightly to one side of the radio tray to balance ?
