Pit light! That a great idea ! I will add one in my pit/carrying case /storage box. Thank You 603kid!
I will used camping neon light, work with battery instead of buying a "RC buggy brand name".
I'm working on a transportation case for my buggy! I want something that will include everything I need: “Portable Work Shop” and "Storage / Carrying Case” all in one. I used second hand material except for “fasteners” (pop-rivet/glue).
I will put tool box rail to make the car jack operate smooth and a rotary plate so I can rotate the buggy and I want to use a kind of Cleco system to hold the buggy on the plate for transportation and engine run! I will add a pipe to put the exhaust away, like real garage. The space on the 2 inch cover, I will put a black foam, carved to hold remote control, tools, spare parts and a bin area made with transparent plastic pills container. I will cover all the inside with black foam (if the buggy can fit in, I just made extension wheel hub and I put 2 double set of tires).
I build a compartment on the rear side of the box, between the wheel bins. I will probably use it like a battery pack area.
Still a lot of time to wait to finish the project. Finding the good thing to re-use is hard, but the harder is to get every tings before going to far!
“Measure twice cut once!”
I re-used garbage for the box and keep the money for the buggy!
http://www.youtube.com/watch?v=P1bFK-l0VQ4
http://www.youtube.com/watch?v=sIB6jLtTs0k
See Yaa!
Frank_514
