ORIGINAL: brushlessboy16
Hello and welcome, just for starters i have done 1/8th scale conversions and so have others like
-Takedown
-Happywing
-RURC
WE all have first hand knowledge of the matter...
Moving on
1. I buy from Mike at RC-monster, RCP is overpriced when you can get a part that is just as well made for less.
plus if it breaks mike will get a new one out to u ASAP
2. The Mamba Max is a great Speed controller, i Run it in my B/L raze, the only problem is that some models dont like running higher then 3s lipo. (explained later). There are many alternatives, depending on weather or not u use mechanical brakes or the Speed controller's brakes.... If u keep the mechanical brakes then your ESC selection broadens-You can get very cheap high voltage plane esc (8s-100a). If u plan on using the Esc brakes you need a car or boat esc, that brings your choices back to the Mamba Max or equivelant.
(unless you want to pay infinite amounts of money for a MGM or Quark)
2A- The motor that the Mamba Max comes with simply put -IS NOT POWERFULL ENOUGH. They are a small motor that will heat up and commit suicide very quickly. You need a Long can motor like the Feigao Xl series or equivelent (wanderer). If u have money to spend i would reccoment getting a Neu, or other high quality motor. But they run for Hundreds of dollars.
XL series-
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
3. Simply, 3s is not enough power. you need a minimum of 4s lipo, 5-6s is favorable..I am running 5s 4000mah in my car. You can still use your current charger, just get one 2s and one 3s. You should be shooting for a battery that is capable of 100a continuous
I bought my batteries from
www.unitedhobbies.com they are very cheap- i picked up my 5s pack for 95 bucks
4. The tooth pitch of the gear on the center diff is Module 1.0, MOD1 for short. Mike at Rc-monster.com sells these
-found here
http://www.rc-monster.com/proddetail...1pinion&cat=40
Ill be happy to answer any questions for you
