RCU Forums - View Single Post - update on 30cc stihl, suggestions requested!
Old 04-21-2008 | 10:42 PM
  #53
fozjared
Default RE: weedeater/chainsaw 39cc for free, where to start?
ok i think i have figured out the problem!! the high speed needle was broken, instead of breaking the plastic i broke the needle itself so all this time i couldn't figure out why when i turned the high side nothing happened!! i pulled all the plastic out and the top portion of the needle, now all that is left to adjust is the little bolt that is deep down in the needle recess on the side of the carb, i can see it, but i can't figure out a way to adjust it..
today i tried a 15x8 prop at a max of 7200rpm and then a 16x6-10 at around 6000rpm max.. all of this was done by adjusting only the low end, if only i could figure out a way to turn the remaining piece of bolt down in the carb on the high side i think i would have a great engine! regardless, i got the big turd to fly here are some pictures of my first scratch built no plans spad with my first weedie conversion as well.
btw, if anyone can think of a way to turn the high speed needle please let me know asap! thanks!
ID:	934392   Click image for larger version
ID:	934393   Click image for larger version
ID:	934394   Click image for larger version
